MAKE YOUR OWN QUESTIONS, BE SURE TO MAKE UP AN ANSWER KEY, MAKE LOTS OF THEM SO YOU CANT POSSIBLY MEMORIZE THEM ALL, HAVE THE WIFE OR SOMEONE OPEN THE BOOK READ A LITTLE BIT AND FOMULATE A QUESTION FOR YOU.
D1.1 Specific- Not actual test questions but may get you looking in the right place. I may not even be sure of some of the answers !
1) Can E6010 Downhill be used for fabrication in accordance with AWS D1.1 for structural steel?
2) Can a Prequalified WPS be prepared for welding CJP grooves from one side without backing for T, Y, K connections?
3) What is the maximum weave width allowed for SMAW for a vertical weld?
4) Is voltage a required variable for SMAW welding?
5) When welding fillet welds in two opposing planes, should the weld be wrapped around the corners?
6) If a welder qualifies with GMAW-S is he qualified to weld with FCAW-S.
7) Can a welder who qualifed on a CJP groove weld in accordance with AWS D1.1 weld on a fillet weld attached to a 2" diameter pipe in the same position?
8) True or false. 1G, 2G, 3G, 4G are designations of positions to be welded in production.
9) What chapter in the code addresses prequalified WPS,
10) What chapter in the code addresses qualification of welders and procedures by testing.
11) What chapter addresses production welding requirements.
12) Does AWS D1.1 prohibit a CWI from inspecting and accepting welds.
General Welding
1) Name 5 types of weld joints
2) Which process uses a consumable electrode and guide tube. SAW, FCAW, ESW.
3) What process has greater sensitivity to detect rounded discontinuities open to the surface in carbon steel? MT, PT, RT, UT
4) Slag trapped in a weld will show up on a radiograph because - 1) Metal is missing where the slag is located 2) The slag casts a "shadow" on the film. 3) Slag absorbs radiation and causes darker areas on the film.
5) What inspection method would be most likely to detect laminations in plate ? UT-Straight Beam, UT Angle Beam, MT, PT, none of the above.
6) What process cannot be used for overhead groove welds. GMAW, FCAW, SMAW, SAW.
And I am sure there are others. Remember that you will never get actual code questions online anywhere. But any welding related questions may help you learn whare to find the answers. And if nothing else, make you know more.
Gerald
