good question. D1.1 table 3.7 lists the max per process, but i have never seen anything that shows a max weld size per wire dia. i do not know that such a thing exists. common sense would dictate that there were such a table. for instance , it doesn't seem right that a person would be running a 1/2 inch fillet weld in the flat position with .030 GMAW in a single pass( could you imagine what that would look like!) but according to table 3.7 it is not prohibited.
JJ
