Up Topic Welding Industry / General Welding Discussion / sa 200 wont start.
- - By JHarlos (**) Date 09-25-2008 01:39
My 79 was running like crap this afternoon so I changed the fuel filter, and plugs one at a time, and cleaned the pionts. Now it wont start. Need help.
Parent - - By raftergwelding (*****) Date 09-25-2008 04:25
did you put the cap on right check the gap on the points i think it's 19 thousandths
Parent - By darren (***) Date 09-25-2008 19:56
crap in carb?
magnito/distibuter?moisture?
do you have spark?
if you have spark then its fuel related.
i know this is obvious but sometimes it gets missed. when all else fails rebuild the carb only takes a couple of hours and really improves the fuel economy and overall performance.
darren
Parent - - By pipeliner 798 (**) Date 09-26-2008 01:13
i have a 79 also, if you get any and i mean any moisture in the cap it either want start or will fire and sounds likes like the head is about to fly off (bad popping and untimed fireing). if you dont have a filler guage to check the pionts a dollar bill is pretty dam close, it will run fine set with a dollar.  id bet a dollar to a donut that its either moisture or you didnt get the points set back, wd40 is the trick for moisture
Parent - - By JHarlos (**) Date 09-27-2008 01:21
fixed it yesterday... new dist. cap, button, points and condenser and something there did it. But it didnt have moisture
Parent - - By raftergwelding (*****) Date 09-27-2008 03:55
might of been burnt points it happened to me once
Parent - By JHarlos (**) Date 09-28-2008 23:43
yeah pretty sure thats what it was
