Up Topic Welding Industry / Technical Discussions / Nickel thin film
- - By thinfilmguy Date 10-12-2001 13:19
Hi, does anyone here work with evaporated or sputtered metallic films? If so, I would like to know a good way to make a good contact on a 1-micron thick nickel film. Wire bonding with gold wire doesn't work unless you add a gold electrode. I'd like to weld directly in the nickel.
Parent - By pp_turtle Date 10-09-2002 22:48
The company I work for has been sucessful with parallel gap welding (resistance spot) gold ribbon wire (.001 x .003) to hard nickel plating on a glass epoxy substrate and sputtered Au on Si insulated metal.
