Hello qaqcmpm, I don't believe you will want to consider replacing the hydrotest for one with air/nitrogen. There is a considerable amount of difference in a couple of things concerning what you are proposing. A hydrotest can be conducted with a much greater degree of safety. If you were to experience a rupture of the pipe spool there is way less chance of personal injury. When a fluid under pressure is released in an event such as a rupture it will not act in the same manner because a fluid cannot be compressed, it can still exhibit violence but not nearly as much as a gas. If you pressurize your spool with a air/nitrogen you will be compressing many times the volume of gas that it would occupy at atmospheric pressure. So as an example and NOT A REAL ONE, if you had a tank or something that had an area of 10 cubic feet and you pressurized it to 450 bar it might now contain a 1000 cubic feet of air/nitrogen before it reached 450 bar, if there was a rupture, that 1000 cubic feet of air/nitrogen would immediately try to reoccupy it's original space and volume. It would result in an immense explosion. This would be the example of why they do hydrotesting instead of using air/gas. So please don't even think about substituting the hydrotest. In other words stick with the accepted method of testing. Best regards, aevald
