If galvanizing after fabrication, don't forget internal venting if you have hollow (pipe or tube) pickets. You could use internal venting where pickets attach to the frame, and then use fill and vent holes in the frame, rather than using vent holes in the pickets. The gate will look better than having all those exposed holes that may need to be plugged after galvanizing. The American Galvanizing Association has a free chart they'll send you that shows design for galvanizing, which covers minimum hole diameters and proper fabrication practices.
