Up Topic Welding Industry / Technical Discussions / Hand held bevelers
- - By Lawrence (*****) Date 10-02-2008 20:31 Edited 10-02-2008 20:40
We are spec-ing out hand held bevel mills and my choices have come down to
Jancy BM20 (slugger)
Horsepower 1-1/2 HP
Beveler Nominal Amperage 14A / 120V
Maximum Current Load 18A / 120V
Start-up Current 11A / 120V
Revolutions per Minute 3450 RPM
Cutting Speed 1800 SFPM
Angle Range 30º to 60º
Bevel Width (Maximum) 3/4"
or
Heck HEC9000
Bevel-Mill Model 9000
Minimum workpiece thickness 1/8" - 3mm
Minimum bevel 0
Maximum bevel (B) 1 1/4" - 32mm
Bevel Angle 15 - 45
V-block length 8 3/4" - 219mm
Number of inserts 10
Motor 1 1/2hp, 110V
Weight 50lbs - 24kg
It looks to me like the Heck will bevel almost twice the thickness and only costs a couple of hundred bucks more...
I would love to hear from folks who have worked with these tools.
We will be using them in a school setting, predominatly on plate... Teaching fab, supplementing training for flame cut bevels and hand ground bevels.
Thanks in advance.
Lar
Parent - By jwright650 (*****) Date 10-02-2008 20:50
A salesman brought the Heck Industries model out for us to try. I'll admit it, it does a great job at beveling column flanges and milling a bead of weld completely flush.....just a bit pricey for our liking. The guys here can setup and burn the flanges of a column with the buggo track torch quicker than we could bevel the flanges with that hand held milling machine....If the flanges were thin, I could see the milling machine winning the race, but we also ran into another problem....we could only mill the top flange of the beams that were beveled for field moment welding...the bottom flange would still have to be burned with the torch because it is beveled so that all of the field welding is downhand and not over head.
Parent - By aevald (*****) Date 10-02-2008 21:42
Hello Lawrence, over Christmas break last year I worked a shut-down of sorts, where they were going through and reinforcing all of the roof beams in a large manufacturing facility. 1" flat bar was fitted and stitch-welded on both sides of the web on the underside of the top flange. It required beveling one edge of a 1"x5" flat bar along it's edge for the full length of a number of 20' bars in order to clear a pre-existing weld when the beams were fabricated. They originally attempted to do this with a track burner, major distortion issues. They finally got smart and invested in a couple of the Heck bevelers, likely the very model you are considering. I felt that they did an excellent job and also very quickly. They are also very capable of doing some serious bevel preparation with a single pass. Only real criticism I can recall had to do with the screws that fastened the inserts to the spindle assembly, if you weren't fairly careful you could damage them and make it hard to do the change-outs. So if you go this route certainly stock a supply of inserts as well as the retention screws that hold them in. Best regards, Allan
Parent - - By cfrancis (**) Date 10-07-2008 17:39
Hi
We do alot of beveling of plates as well. I've been wanting to look into these bevelers for years as well. We do the majority of it now on track mounted "Bug Burners", which works great and very quick with small setups. Would love to hear more from folks who are using these bevelers...
Parent - By swnorris (****) Date 10-07-2008 19:09
We've used Heck for several years with no problems.
