Up Topic Welding Industry / Technical Discussions / impact test temperature
- - By qaqcmpm (*) Date 10-04-2008 06:54
I have 2 pqrs one is qualified with impact @-29 degc & another one qualified with impact @-46 degc. If i combine both the pqrs for a new WPS for what temp of impact test can i use this? is it acceptable for any code of construction?
Parent - - By jon20013 (*****) Date 10-04-2008 07:23
Depends on what processes, materials, thicknesses, etc.,  If all things are the same, I would base the WPS on lower temperature.  What is the constructing code?
Parent - By qaqcmpm (*) Date 10-04-2008 09:50
Process: GTAW, material: CS, gtaw upto 17mm & to be combined with SAW, CS. code of construction: asme sec viii div 1
Parent - - By fit.to.a.flange (*) Date 10-04-2008 07:48
By looking at the figure, I guess he is referring to B31.3. Yes I agree with Jon if all essentials remained unchanged, then the lower temperature shall apply.
John boy..
Parent - - By qaqcmpm (*) Date 10-04-2008 09:51
so it is qualified for -46 deg c
Parent - - By jon20013 (*****) Date 10-04-2008 10:05
If both processes were qualified at -46C, then it seems to me you'd be covered, but "possibly" only for the ranges specified in that PQR.  Whats the details on the -29C PQR?  It's hard giving advice remotely, as you might imagine... don't want to lead anyone down the wrong path.
May I ask, what benefit to you hope to gain by combining these 2 PQR's?
Parent - - By qaqcmpm (*) Date 10-04-2008 12:06
We have wps (smaw+saw) qualified with impact @-46 deg c but i want to use the gtaw (another wps qualified upto 17mm thk impact tested @ -29 deg c) for root/hotpass/Ist fill then we use saw in production (where the mdmt is -46 deg c)
Parent - By jon20013 (*****) Date 10-05-2008 00:53
You may not use the GTAW process at -46 if it was qualified only at -29.
