100perpen ,
By the code you should qualify a procedure because the base metal (nut) is not a prequalified material. But what I have done in the past is write a welding procedure and submit it for the engineer to approve. Your welders should be qualified to weld as you have stated "All of our operators are qualified to weld D1.3 and we have qualified operators to D1.1 when welding over 1/8".". The requirement for visual inspection should come from the job specifications.
