Yes, I am aware that this will require qualification, and qualification of our welders to the new WPS (per weld profile, wire diam., wire type, heat input, and all that jazz) . . . and yet, even though qualifying the WPS and the welders is an ordeal in itself, the new qualification would allow us to perform the same procedure on future projects. So, it is worth it to do this. Whereas exposing the areas that need a backgouge and then replacing the material is on a project to project basis . . . and amounts to a lot more work in the end. Thanks!
Andrew
