All,
Thanks for the input. I remembered looking thru B31.3 and could not find anything specific to this matter. Yes, common sense tells that no hydrotest could perform above boiling point or below freezing limit. The client's specification also does not address this subject. But if I am the Owner, I will probably set my ranges to suit the local conditions and bearing in mind that some countries, the summer period could sour to a very high temp when one is to perform such testing.
Regards, John boy..
