Up Topic Welding Industry / Technical Discussions / tig to plasma cutter
- - By master6789338 Date 10-14-2008 10:54
can you hook up a plasma cutter torch to a high frequency ac/dc tig welder and will it work as good as a regular plasma cutter?
Parent - - By DaveBoyer (*****) Date 10-15-2008 03:34
   There are a few combination machines made in China that do both. The arc voltage of a typical TIG welder is about 20-25 volts, A plasma cutter has an arc voltage of 125-200 volts, that is a lot of difference. Energy equals volts X amps, without the higher voltage You just don't have a whole lot of energy.
   I havn't tried what You are asking about, but I doubt it would work well enough to use.
Parent - - By Lawrence (*****) Date 10-15-2008 11:41
Diddn't PowCon at one time have a GTAW/PAC unit?
I loved those red boxes
Parent - By DaveBoyer (*****) Date 10-16-2008 04:53
I can't say that PowCon didn't have such a thing, but they DID have a plasma cutter that You powered with a welder, it was a seperate red box.
