What are the different ways or steps to tell the difference between Cast Steel and Cast Iron?
I come across a lot of pumps that need casing repairs and seal welding plugs.
Is there a procedure, PMI or test that is recommended when there are no markings?
Should I just make a weld procedure using a nickel rod to weld on any casting?
