Hello,
Please pardon my ignorance, but I have encountered a situation with a welding symbol that baffles me.
AWS A2.4 6.2.2 says that omitting the depth of bevel and weld size dimensions from the welding symbol requires a groove weld that extends through the thickness of the joint.
That being said the symbol I mentioned is for welding a LAP JOINT the drawing calls for a 9mm fillet weld arrow side,
and a combination bevel-groove weld with a 9mm fillet weld on the other side. My question is since niether the depth of bevel nor the weld size is
specified for the bevel groove weld on the drawing, is AWS A2.4 6.2.2 applicable to lap joints? Our Engineering dept. says that they believe that it does not apply because the weld joint is not a butt joint, but I can not find anything that excludes lap joints. If anyone can help it would be greatly appreciated.
Thanks,
Shawn
