Are there any groove welds on this particular part? When the guy says he wants failure to be above 24ksi it sounds like he is specing the requirements for a PQR out of D1.2 structural aluminum. 24,000psi is the minimum failure load in tensile pulls for 6061-T6. If you are going buy code and there are groove welds on this part then all you need to be testing is a test plate to qualify a procedure. Then you can do fillet breaks or etching for the fillet weld procedures. Now if your just load testing the part and he wants it to fail above 24,000psi, then i'd say the way you test it is going to determine when it breaks. You might need to go with a whole new joint design. If you have procedures for the 5356 wire and you switch to the 4043, you will have to qualify new procedures.
We had trouble with our tensiles on 6061-T6 in that they pulled at well below 24ksi (18 and 19ksi) and we had to do them over. We were using 4643 filler on 1/4" thick 6061-t6 base material. I found the proublem to be hydrogen porosity in the root and that we got the pipe to hot for to long even with 250deg interpass temps. I also switched to 4043 for sits and giggles and they came out this time. I'm pretty sure it was because I let it cool way below 250 deg for interpass temp and got rid of the hydrogen pockets in the root. Are your failures in the weld or in the base material? If they are in the weld, do you see any shiny little pockets in the broken weld?
