Up Topic Welding Industry / Technical Discussions / Preheat
- - By Taintedhalo (*) Date 10-21-2008 18:19
Does anyone know what the preheat and interpass temp should be for 1" to 3" ASTM A829 Grade 4340? Or where i could locate the temp ranges?
Thanks
Parent - By RonG (****) Date 10-21-2008 20:06
Use the SEARCH function. Search preheat and user G.S.Crisi.
He has a formula (post on here somewhere) that I have lost thru the many changes and migrations of PC's.
It uses the Carbon content to determine preheat range of materials.
Parent - By DAYANARA (**) Date 10-23-2008 18:49
I prefer review AWS D1.1 Annex normative I.
The PCm es very importan in  Hydrogen control, because, is possible  risk cracking for hydrogen inducen
Dayanara
Parent - - By RBeldyk (**) Date 10-23-2008 20:13
Here is a method for estimating Preheat
Calculate the CET
CET = C + (Mn+Mo)/10 + (Cr+Cu)/20 + Ni/40
Calculate the Preheat using CET
Tp = 697*CET + 160 tanh (d/35) + 62*HD^0.35 +(53*CET-32)*Q-330 [Degree C]
where: d is the thickness in mm
           HD is the hydrogen content in ml/100g per ISO 3690 weld deposit method
                typical values HD = 5 ml/100g - SMAW, FCAW, SAW and HD = 3 ml/100g for GMAW
           Q is the actual heat input in KJ/mm Q = eff*Voltage*Amperage/(weld speed)
                typical eff  = 0.8 SMAW, GMAW
                                = 0.7 GTAW
                                = 0.9 FCAW
                                = 1.0 SAW
   tanh() is the Hyperbolic tangent
If you want to experiment iterative approach
1. measure the temperature of the steel
2. weld the first pass mesaure the time it takes the weld to go from 800 to 500 degree C adjust the preheat to obtain a t8/5 greater than 8 seconds; allowing the HAZ and weld emough time to transform from martensite.
Parent - - By Taintedhalo (*) Date 10-24-2008 12:57
Thank you all very much.
Isn't Heat input VxAx60/Travel speed
Parent - - By RBeldyk (**) Date 10-24-2008 13:20
Pay close attention to units.
In my post above the weld speed is mm/sec versus ipm in yours.
Parent - By Taintedhalo (*) Date 10-24-2008 13:21
K thank you
