Your plate has to be seven(7) inches tall and two three(3) inch wide with the 22.5 degree bevel. The backing strip shall be no less than 1/4" and I think it said the minimum width of your backing strip is three(3) inches unless it is being removed to inspect the root then it's no less than 1 inch.
I just did mine the other night, same position. Just ran a stringer root, maybe a very very slight weave just to tie in the edges. Ran a small weave hot pass, a filler pass, a filler pass and a weave cap pass. Have the machine set right and you really won't need your chipping hammer, my slag would roll right off the fillers and the cap. Some say use a grinder, others say no. I used the grinder just enough to knock off the high spot on my restarts and just barely hit those.
Practice, what I did, ran stringers on old scrap plate getting real tight welds. Actually did the same working on my cap. Just ran on flat plate trying to pick what one of the different styles I liked. Kinda got a weave I guess. Also played with the heat alot, up and down. Run a rod see what it does, look at the spatter, listen to the arc, watch the slag, then turn the knob and do it again.
Good luck with it!!
