Up Topic Welding Industry / General Welding Discussion / mathey pipe beveling machine
- - By robgreg1978 (**) Date 10-29-2008 01:02
I just bought a mathey 1sa pipe beveler, but it only came with one set of spacers. where would be a good place to get the other 3 spacers that go with the machine. I emailed mathey directly but no response yet.
Parent - By TimGary (****) Date 10-29-2008 12:58
They're pretty easy to make yourself, in a pinch. Especially if you have access to a lathe.
Otherwise, any welding supply distributor can get them.
Tim
Parent - - By raftergwelding (*****) Date 10-29-2008 13:00
call the people you bought it from and ask them where the rest are unless you bought used but yeah any lws should be able to help you
Parent - By Johnyutah (**) Date 11-08-2008 00:26
If you did buy it used just find a guy who has the spacers get some 1/2" cold rolled SS and some SS bolts and make your own.
Parent - - By raftergwelding (*****) Date 11-08-2008 06:05
i bought a h&M machine used it onl came with the 4'' dogs i had to get a set thru my lws they told me they couldnt get indivdual dogs just a full set and it was 65.00 that was 2 years ago i have seen them made with regualr bolts but was toild it was a pain in the neck to get them done
Parent - - By robgreg1978 (**) Date 11-08-2008 15:01
I have seen these new dogs that are all in one. they look like little steps. 40 bucks I have ordered them but have not recieved them yet. i used some bolts once but it took to long to adjust each bolt to get the machine square with the pipe and it still wasn't a real square cut
Parent - By bullsnbets (**) Date 11-08-2008 22:04
Those are called "Cuboid Spacers".
