This joint can be welded using ErNiCr-3 GTAW, or ENiCrFe-3 SMAW (Nickel Base "A" "82 or 182"). We use these fillers for all our dissimilar welding of 9Cr materials to SS, and have had no problems associated with the welds. Since you are welding an "L" grade SS, PWHT at 1400 F should not be an issue with the SS concerning carbide precipitation.
When we get into a situation where we are welding a non "L" grade SS to a 9 Cr material we will butter the 9 Cr piece with the Nickel welding rod (two layers) and PWHT the 9Cr piece. After PWHT, we weld the 9 Cr piece to the SS with the Nickel weld rod. This joint then does not require PWHT. This technique can also be applied to the "L" grade material if you are not comfortable with the idea of performing the PWHT on the "L" grade SS.
