Up Topic Welding Industry / Technical Discussions / what is PA, PF, PG.....?
- - By Nandesh Kumar (*) Date 11-02-2008 15:31
Hi,
What PA, PG, PF, HLO 45 etc. stand for (which correspond to 1G, 2G, 3G etc in AWS ) as applied to European standards?
Parent - By 3.2 Inspector (***) Date 11-02-2008 16:31
It is illustrated in EN 287, which is the standard used for qualifying welders.
http://www.gowelding.com/wp/enpos.htm
3.2
Parent - - By Stephan (***) Date 11-02-2008 16:41
Nandesh,
These are the EN 287 designations for welding positions.
PA = Flat (both butt and fillet)
PB = horizontal (fillet)
PC = 2 G
PD = horizontal overhead (fillet)
PE = overhead (butt)
PF = perpendicular uphill (both fillet and butt)
PG = perpendicular downhill (both fillet and butt weld)
Best regards,
Stephan
Parent - By 3.2 Inspector (***) Date 11-02-2008 16:47
May I add HL-045 (6G) which might be the most used position for certifying welders.
3.2
