Up Topic Welding Industry / General Welding Discussion / Clasic One?
- - By Robert48 (**) Date 11-08-2008 14:40
I have a 90's model clasic one. It has the OHV motor but has a smooth round generator barrel the same as my red face. I have replaced the armature bearing in both machines and I can't tell a diference between the two. They both weld very good you could switch leads and never tell which was which. I just wanted to know if this was a common machine because I looked at a Clasic one on the for sale page that is nothing like mine.
Parent - - By K.Sexton26 (**) Date 11-10-2008 05:27
It depends on the year model of the classic 1 some had hexagonal and some had the original fjw round barrel like the red faces. I have a 1997 classic 1 TM27 engine it has a round barrel, im not sure about when they swaped to the hexagon barrel i think 1993 then a couple years later went back to the original because they didn't perform like the round barrel machines did i know they made sa200s to 1992 then 1993 started calling them classic 1s but the model# still sa200. Ive had my machine next to several different red faces and held my own like you said there is no difference in the machines they both have same generators made the same way.
Parent - - By ZCat (***) Date 11-12-2008 02:08
whatever happened to the Classic 1? They just stopped making them?
Parent - - By K.Sexton26 (**) Date 11-13-2008 02:02
Lincoln changed from the classic 1s to the pipeliner 200g-200d models 2000-2001, i think thats the year. Then they had alot of trouble with the pipeliner 200g the engines were crap they had GM motors in them so they went with the 200d
Parent - - By DaveBoyer (*****) Date 11-13-2008 03:41
Which GM gas engine was in those?
Parent - - By raftergwelding (*****) Date 11-14-2008 01:57
i dont remember the number on the engine but they were junk they had a computer and electric fuel pump on them go figure it was a 4cyl engine a guy i worked with was always having trouble with his 200g he ended up buying a miller and then quit welding to go be a deputy sherrif
Parent - - By DaveBoyer (*****) Date 11-14-2008 03:30
GM makes, or made a good 4 cyl. engine that is used on the Mercruiser I/O systems. It is based on the old Chevy II engine from the early '60s that was later called the "Iron Duke" and use in late model Vega's after the aluminum block proved to be crap. I don't know how good this engine is whith electronics & computers controlling it. I wonder if this is the engine they used.
Parent - - By RioCampo (***) Date 11-14-2008 13:05
Don't know the model number but I believe it was a 3.0 liter GM engine
Parent - - By DaveBoyer (*****) Date 11-15-2008 04:47
If it is a pushrod engine, it is probably the same one Mercury Marine is using.
Parent - - By Billyjoe (***) Date 11-16-2008 04:18
lincoln classic 1 an 2 an classic 111 where made in canada ,when they closed the plant in canada they stopped making the classic machines ,if I'm not for sure 1997 was the last year for the classic  ,
Parent - - By K.Sexton26 (**) Date 11-16-2008 05:15
lincoln also made classics in the united states they had two different codes C1 was canada code U1 was usa code
Parent - By Root Pass (***) Date 11-16-2008 14:04
I have a Linclon calalog from 2004 engine drives offered- Pipeliner 200g (GM 3.0 L4), Pipeliner 200d (Perkins), Classic II (Deutz), Classic 300g (GM 3.0 L4), and Classic 300d (Perkins).
The next oldest catalog is from 2001- Classic I (Wis-con TM27 gas),Classic II (Deutz), Classic III (Wis-con TM27 gas), Classic 300d (Perkins).
1999 same line up as 2001
1998 same as  '99 and '01
