Up Topic Chit-Chat & Non-Welding Discussion / Off-Topic Bar and Grill / Ok, Can someone explain how this one works...
- - By PlasmaHead2 (***) Date 11-12-2008 01:28
I have an old TV that doesn't have an antenna, and instead of going and buying another set of bunny ears, I tried something else.
The TV has those older style coax cables that have a pin inside a threaded nut, so in desperation I tried putting the pin in a 30/30 hollow point.
Somehow, which is why I'm asking all of you more experienced people, this setup works better than a real antenna.
Any ideas? Thoughts? opinions? Other crazy things that work when theres no reason they should?
Thanks
-Clif
Parent - - By aevald (*****) Date 11-12-2008 01:35
Hello Clif, I can't help myself, that's just one more reason not to give up your rights to guns and bullets. Your TV reception would obviously suffer. Best regards, Allan
Parent - By BryonLewis (****) Date 11-12-2008 01:36
I knew the 2nd Amendment would come in handy!!! lol
Parent - By DaveBoyer (*****) Date 11-12-2008 03:43
You must be in an area with a strong signal.
