Gents,
I may be missing something, but I don't see a reason for the filler material being of higher strength than the weaker of the base materials. A sketch, or better description, of the configuration of what the parts look like, how they fit together and what the finished componet actually does, would be of benefit. As always with HSLA materials, proper preheat and PWHT is of great importance. The important part of this seems to be the HAZ of the 4350 shaft, and the proper care, post welding.
Joe, He really didn't say that He needed to maintain the 330 Brin. hardness, I just guessed He needed to.
I don't have the specs at hand, but I think the post weld schedule You mentioned would leave the shaft pretty much softer.
A method of only heating the needed area would probably be a good choice if there is enough distance between the weld and where the shaft needs to be 330 Brin..
I don't know what the best electrode would be. As Fredspoppy points out little would be gained with a weld stronger than the Gr 50 plate, but the electrode must be compatible with both materials.
Dave, Fredspoppy
I agree that from a structural strain standpoint the 80 class electrode is all that is necessary for the A-572 Gr.50.
I used 120 class electrode, because I know it is compatible metallurgically and heat treatment wise with the 4130, 4137, 4140 and 4150 material. I can tell you from experience and test, that the A-572 Gr-50 will not be affected if you use 120 series electrode with or without PWHT. So, while it is overkill to the A-572, it is not necessarily underkill to the 4150. Why take a chance?
Anyway, I admit I am not a Metallurgist, and I really screwed up by missing that 330hB requirement.
Joe Kane
