Here's the way I see it (please remember that all numbers are for comparison purposes only):
Go to the hardware store (Ace by me has a good selection of these), and compare the ratings on the real forged eyebolts (say for comparison purposes 3000lbs for a 1/2" one), with the eyebolts that are just a bolt, bent into an eye shape, and not welded shut (say 300lbs for the same 1/2" one).
The difference is dramatic, BUT, the rating of the forged eye, is based on strictly pulling straight. The bent eye, may have its rating based on straight pull testing, but because of its shape (and the fact that the eye is open), it will fail when the eye bends open, and so its strength when loaded at 90 degrees is about the same as straight on (assuming its attachment is solid). I would trust the forged eye at 90 degrees, up to the point that the shank risks bending . . .
The difference is like being able to lift a car straight on, or a lawnmower otherwise.
Now, the OP referred to 45 degrees. Unfortunately, that's not halfway between straight on, and 90 degrees.
The force in shear, is the tension on the chain, times sin(angle). When that force exceeds the bending strength of the bolt, it will bend.
sin(45) is .707, so if the bending strength is 1/10th the tensile rating, you should not exceed 14% of the rating, not 25%.
sin(30) is .5, and .1/.5 = 20%.
here's where my info comes from, watch out for buying shackles from a hardware store, they are cast and not forged
Nice chart. The numbers I was going through were just to show that for a -shoulderless- eyebolt, even a small deviation off vertical lifting severely reduces your capacity.
Yes, a shoulder helps enormously in preventing the shank from bending. I agree that its bad practice to pull these at more than 45 degrees from vertical, but that doesn't mean its impossible. Its just you would need something almost large enough to lift a house when vertical, to lift me, when pulled from the side.
Still, at 575lbs, and way heavier than my puny mill drill (which is the second largest thing I sometimes lift in my shop), I still only use 1 ton (and more) rated equipment, and load it the correct way, to lift my Miller AEAD-200le, and it still scares me when its more than an inch from the floor.
Funny thing, is none of this really speaks the the OP.
And, every time I buy forged eye-bolts, they come with matching nuts, so I don't even know how to answer that one. Hummm.
I would agree that the OP got kind of derailed, I just took that rigging class a couple weeks ago, so its still fresh in mind, and since it was under the safety section, I wanted to throw out some of the safety issues involved in using eye bolts. Sholderless eyebolts are never to be used except straight vertical lifting.
The matching nuts are matched for a reason, your not supposed to swap them out! that should have been the answer for the OP. I'm not sure you can buy replacements without buying the whole thing, I have tried to find shackle pins and have yet to find them without replacing the shackle!
while were off the subject of the OP I had mentioned before that people need to be aware that buying shackles from a hardware store that most do not have a rating on them, and therefore are cast, and will break even when lifting under the rated load for the size shackle used. So I hope everyone looks at their shackles and if there is no load rating on them do not use them for lifting.
Keep it safe, Carl
To elaborate on the eye bolts used at 90 degree loading: These were screwed into tapped holes in the edges of plates, castings or weldments. The eye bolts had a lockwasher and a heavy nut permanantly run down against the shoulder, and were screwed in with the nut as close as possible to the edge of the part without influencing the fair lead of the eye to the hook. We used 1", 1 1/4" & 1 1/2" eye bolts this way, and would on ocasion bend [and discard] them. In my years at that plant I never saw or heard of anyone breaking one.
The shop made lugs I mentioned used 1", 1 1/4" & 1 1/2" bolts, but the bolts were in shear with these and had much greater capacity, as there was no bending or prying forces.
Eye bolts are designed for straight vertical pulls. Safe working loads drop off to 25% for 45° pulling angles.
