AL, ASNI B30.20 applies to structural and mechanical lifting devices. The customer has specified in the bid that it must comply with that standard,which states in 20-1.2.2 (a) All welding shall be in accordance with ANSI/AWS D1.1. ASME BTH-1, It states that it provides the requirements for below -the- hook lifting devices and implements the requirements of ASME B30.20. And your right on Al, they do relate to the Design & Fabrication ,Testing, Marking, Modification/Re rating, Guarding, frequent, Periodic, Operational Test, Rated Load Test Maintenance, Training/Qualification. I was just asked to give my opinion on what I know would be there responsibility and requirements as a Fab.Shop to build it.They are a new outfit that is really trying to run a Quality & professional business and they ask me for help from time to time. Anyway I gave them what I knew but the fact remains I do not have a D14.1 therefore My assessment is incomplete and I do not know what the D14.1 might change in the Inspection Requirements and the meaning of "Qualified fabricator" As the bid states it must be build by. I have my own ideas, but with out the D14.1 their just ideas and that will not fly. I suggested that they call the Engineer and straighten the remaining questions out. They did not know they could do this. They called me back and said it worked, problem solved. I'm buying a D14.1
WHIP.
