The best way to get your root opening is...
Determine the size and type of rod you want for your root pass. EX....E6010,6011,7018, 3/32, 1/8, 5/32, 3/16..etc.
Also read the prints because the engineer may have a specific root opening that he wants. If you're going to have a full pen. weld, you can go a little heavy on the land to make sure you can use a bigger electrode for a larger deposit. That way you can possibly just backgrind the other side, and not have to gouge.
As far as increments for 1/2", 3/4", 1".....Use a root opening that you're comfortable with...
