I've read the commentary and I agree with you Al. What I don't understand is this...
Example:
A W12 x 35 beam with a continuous 1/4" lintel plate intermittent fillet welded to the bottom flange versus the same beam with a 1/2" lintel plate intermittent fillet welded to the bottom flange.
The maximum spacing for the 1/4" plate would be 6" and the maximum spacing for the 1/2" plate would be 12".
The "spacing of intermittent weld connecting a plate component to other components shall not exceed 24 times the thickness of the thinner plate nor exceed 12" rule would apply, per 2.11.2.1 but, that doesn't change the "sealing" issue in the commentary. Both joints are still doing the same thing. It seems odd that the welds on the lighter plate would be closer together than the welds on the heavier plate. I guess that the lighter plate would be more prone to bowing, therefore needing the welds closer together to ensure a tighter fit. As I wrote this, I think I may have answered my own question.
I believe you did. :)
Buckling is inversely proportional to the thickness of the member (plate). A 1/2 inch plate is twice the thickness of the 1/4 inch plate, but the 1/2 inch plate would experience 1/4 the buckling of the 1/4 inch plate for the same conditions. That being the case, the welds have to be spaced closer on the 1/4 inch plate than they do for the 1/2 inch plate to prevent buckling which would result in a space (gap) between the 1/4 inch plate and the other member (a beam perhaps).
Totally irrelevant to the intermittent spacing issue but following the same principle you put hangers more frequent on small diameter pipes and spaced further apart on large diameter pipes. Something like 3/4" steel pipe gets a hanger every 7' and a 12" steel pipe gets a hanger every 23'.
By 803056
Date 11-29-2008 14:08
Edited 11-29-2008 17:04
I think the hanger spacing is more related to the dead weight of the pipe and its contents. The smaller diameter pipe has a small moment of inertia and sags more than a larger diameter pipe. The objective is to eliminate any low spots where fluids could collect and free draining would be impossible. The concerns could include freezing, condensation causing "slugs" of condensate to pass through the system and damage equipment down stream.
Sagging, buckling, hangy down things, yep I see where you are going.
P.S. - I hope everyone had an enjoyable Thanksgiving!
