Hummm. Well, lasers have been used to "spot weld" detached retinas for some time.
This seems to be a little different. Each side of the wound is buttered with a bio-compatible heat-activated glue (I guess that it is very similar to hide glue . . . ), and the laser is used to melt the glued sides together.
Without melting the tissue under the glue, wouldn't this be more of a "laser soldering" process?
