Rob I weld with inconel ALL the time at work.... pretty much it handles exactly like stainless steel does. It is a little more finiky about how aggressive you have to be about getting in and out of the puddle (so the end of the rod doesn't ball up on you), and it likes LOTS of argon shielding. (I use a purge box whenever possible on smaller items). I use RED tungstens with this, of course, and sharp sharp points on them. Best to keep that tungsten as clean as possible too.
Sometimes the puddle with inconel may not look as super "clean" as stainless does with that one defined fish eye, this may take a little getting used to, there may be little tiny and more than one piece in there. This is WAY the case if you have the amps down too low (I do allot of buildups and have to do it this way anyways). It looks very mukky, but turns out ok in the end. As long as it's nice and shiny when you're done, or whatever color is on there brushes off easily, you're ok.
I don't know what else you'd like to know about this metal.... I'm rather fond of working with it :) But the "colors" do show any lack of shielding, or if you let off at all. AND by the way, I am certified with inconel....
Jenn
EDIT < here's a tidbit from an article that describes what I'm talking about as far as the puddle not being as "clean looking" :
"Inconel 625 can be welded using conventional stainless steel TIG welding techniques. Inconel Filler Metal 625 rod is used to weld Inconel to Inconel as well as to dissimilar metals including stainless steel. Inconel weldments are high strength and are highly resistant to corrosion and oxidation. Many welders describe that welding Inconel as "dirty". In other words, the weld pool appears to be under a "skin" and is not well defined. In addition, the weld pool is somewhat "sluggish" as compared with steel or stainless steel. These characteristics tend to result in a "coarse" appearing weldment as compared to stainless steel. Welding Inconel is not necessarily more difficult to weld than stainless, just different. "
END EDIT<
