Up Topic Welding Industry / General Welding Discussion / pay ?
- - By js1369 (*) Date 12-08-2008 01:35
2 question's
1: what does built-in-overtime mean?
2: what is average wages for shop fitter/welder in the midwest?
Parent - By david bean (**) Date 12-09-2008 19:22
a good fitter/welder should be in the 18-22 range in a non union shop, in the las vegas area.
But work is slowing down in vegas. layoffs are happening.
Parent - - By Lawrence (*****) Date 12-09-2008 19:47
Hey Js
I'm in Wisconsin and there is a good market for welders in the centeral (Milwaukee) and northern areas (Appleton/Sturgeon Bay)
Journey level wages prolly range from 18-20 depending on process and experience. Some higher and some a bit lower until you prove yourself.
Go here and type in "welder"  and you will see several hundred opportunities.
http://www.dwd.state.wi.us/JobNet/mapWI.htm
Parent - - By js1369 (*) Date 12-10-2008 00:30
thanks Lawrence, I have only been doing fit-up for about 2 years now. I guess here in Oklahoma if the sop thinks you are good at one thing they try to have you stay with it.
Parent - By Tommyjoking (****) Date 12-10-2008 14:18
in shop .....The average based on what I have been offered for "general" fitting/welding all over the US is about $20 for the last 5 years for experienced help.  If you add full boat fabrication to that resume ....$25 to 27.50 on the outside.   Add machining and you might can pull more in small specialized companies.
I want to go back to piece/inch based pay  I made a helluva lot more money when I competed directly with my peers then by the hour.
