Take a 12x26 and split to get a WT6x13 and was not split properly in the middle resulten one being 6 1/4 and the other 5 3/4 therefor making an insulficint member.I am trying to find a tolerance for the WT.I haved searched and searched with no luck, could anyone help.
Depth tolerance should be +/- 3/16". Half the nominal depth of the W12 x 26 is 6 1/8", so the 6 1/4" depth would be acceptable and the 5 3/4" depth would not. Check with the EOR if the 5 3/4" depth would be ok to use..
