Up Topic Welding Industry / General Welding Discussion / .062 alm wire on a Millermatic 350p
- - By 1fastguy (**) Date 12-11-2008 14:52
Has anyone tried to run ER5356 Alm 1/16 wire on a Millermatic 350P machine? Just wondering if you can. There is no info on the miller website about running this big wire in this machine.
Parent - By Lawrence (*****) Date 12-11-2008 15:24
For sure you can change the rollers and run traditional spray transfer with a push-pull or even a regular whip. Just be careful to keep the whip straight and if you have a short whip that is even better.
I have a call in to a friend @ Miller who can give answers about the GMAWP and large bore wire..
More later
Parent - By Lawrence (*****) Date 12-13-2008 17:28
Word is that the 350P does not have the horsepower to Pulse 1/16 Aluminum.  It will for sure run it with traditional spray transfer but the starts may be a bit rough.
The XMT will run 1/16 Alum GMAWP.
Parent - By sra (*) Date 12-15-2008 01:52
The 350p works well with .045 alum. 10' gun, non-metallic liner,oversized id tips, push process and factory pluse settings.
