I agree with JS55, the repair of the cracks would require a qualification using a butt joint and a groove weld. The surfacing welds would require a separate procedure.
The crack repair is required to address a problem with the base metal. The repair would be required to produce mechanical properties equivalent to the properties of the base metal. The surfacing welds are a separate issue.
Your qualification becomes quite complex if you repair the cracks with a filler metal that has properties considerably different than the properties of the base metal.You would have to qualify a procedure where the surfacing welds are on the filler and possibly a separate surfacing procedure for the base metal. A successful procedure for the surfacing weld on the dissimilar filler metal does not mean the surfacing material is compatible with the base metal or vice versa.
