Up Topic Welders and Inspectors / Welding Equipment Classifieds / Wanted for Code 3311
- - By ramsay (**) Date 12-16-2008 20:12
Hi all: Just got a beautiful original shorthood air cleaner assembly thanks to Kay at Bill's and need a decal for it if anyone knows where I can find one...
Also, does anyone know the proper opening of the little flap on the choke butterfly on a Marvel Schebler Carburetor? I need it to be right because I intend to hand crank this machine.. Thanks; Mike
Parent - By raftergwelding (*****) Date 12-17-2008 21:43
i didnt know there ws a setting for the butterly i just pull the choke cable til it stops and it fires right up might ask Kaye
Parent - - By KSellon (****) Date 12-19-2008 19:38
give me a week or two and I will get one for you..
Parent - By ramsay (**) Date 12-19-2008 20:03
Thanks Kay:  I found the little spring I needed for the butterfly flap at Ace Hardware for 71 cents lol.. It stretches across the butterfly and restricts the flap opening that is on the butterfly... This is a Marvel carburetor.. It is really easy to start now with a cpl turns of the crank.. Mike
