Have them manually weld the poor fit-up joints and the problem is solved. The orbital will be inconsistent with poor fit-up and would have the settings changed dam near every time to produce a good weld. What grade of stainless are you using? Straight fittings are out there, you just have to find a good supplier. The electropolished fittings that work are a pretty penny though.
