I am still using WordPerfect and it seems I am the holdout here. Most of my clients use MS products, and as you know, when they go through the conversion to Microsoft, the graphics and some text may get jumbled. If the forms you want are only used in house, then I think the WP format is the best. You can customize these to your specific requirements. If you have to electronically transmit these, forget it (other than a fax or scanned document).
I work with a wide variety of processes, materials and applications, therefore I have designed my own forms. These must be flexible to accomdate AWS, ASME, AWWA, Mil. Std., etc. If not, you will have several WPS/PQR/QPQR forms to choose from. Just transfer the information YOU require on your forms. Otherwise, there will be a lot of "N/A's" that are not needed.
