I read at about a 4th grade level and couldnt do much but add and subtract when I went to welding school and when they put it in terms of pipe runs I got it. If the insturctor is any good you will do fine. Its more about skill and work ethic than anything else unless you want to be a fitter. Then you need to learn the math. Go for it man its a great trade if you dont mind traveling.
