Up Topic Welding Industry / Inspection & Qualification / WALL THICKNESS MIN B16.9
- - By Mikeqc1 (****) Date 12-30-2008 18:43 Edited 12-30-2008 18:52
Please correct me if this is not true or confirm if it is the min wall thickness for 90 deg (4"sch 10 304-304l) elbow is 87.5% so this elbows wall thickness cannot be less than .105" right.
Thanks
MDK
Parent - - By Jim Hughes (***) Date 01-02-2009 12:38
MDK,
That is correct. Keep in mind that fittings will some times be a little thicker. It would be wise to measure the actual fittings your dealing with instead of taking standard thickness as gospel. Also look at your contract specs. for corrosion allowances.
Jim
Parent - By Mikeqc1 (****) Date 01-07-2009 16:59
thanks,
i found some of these to way undertolerance.
MDK
