Up Topic Welding Industry / General Welding Discussion / plumb bob or "STRING" line
- - By stkwldr (**) Date 12-30-2008 22:48
Does any one have any clever ways of storing string from either one of these two items.  Does any one have any handy homemade reels they can post pictures of.  I just used over 1000' of string for a fence line and that stuff is hard to wrap back up like it came and tangles can make anyone mad.  Just looking for ideas.
rs
Parent - By hogan (****) Date 12-30-2008 23:09
Mine is not 1000' but I use a reel from a kite.
Parent - By Joseph P. Kane (****) Date 12-30-2008 23:09
Stickweldr
I use a cheapo $18.00 flycasting flyreel, ( It will not hold a thousand feet however.) for my camber and straightness stringline.  For my 32 ounce plumb bobs, I use an H-frame. For my 8 ounce plumb bobs, I use a gammon reel.  I also have a Bazooka Bob, for column plumbness, which has no external string.  For long stringline work, as with progressive assembly, I use a 35 pound, 12 " roll of 0.045 stainless steel electrode.  I use 50 pound pull magnets to hold the string line taught, and wedge lock tensioners or Bessey clamps for the wire line used for progressive assembly camber measurements.
Joe Kane
Parent - - By 522029 (***) Date 12-30-2008 23:25 Edited 12-31-2008 13:55
I use a chalk line reel (un chalked) for the plumb bob we use the most. Obviously not good for 1000' though.
Griff
Parent - By lonestarwelder7 (**) Date 12-31-2008 20:00
I use a chalk line reel too, but I use fishing line, it works for me but dont get it to close to a hot weld.
Parent - - By OBrien (***) Date 12-31-2008 00:11
Do you mean 100'?
Parent - - By stkwldr (**) Date 12-31-2008 01:10
I just got done doing some fence and I bought a string line of 1100 feet.  Rolling that thing is us a job init self.  My plumb bob is a whole lot shorter and that i wrap on a small piece of tubing.  just looking for a quicker method.  Chalk line holder sounds good.
Parent - By ctacker (****) Date 12-31-2008 01:33
I use a chalk line holder with 90LB test parachute string, its very thin string and strong. you can get at least 2 times more string than regular chalk line in the holder.
Parent - - By bbwinc (**) Date 12-31-2008 01:36
Use a old mig wire spool. Make it into a large flyrod reel, that will hold a 1000ft maby 4000ft.lol
Parent - By ANDY LARKINS (*) Date 01-02-2009 19:43
Try one of those orange estention cord holders with the handle in the middle and the crank up handle.
Parent - By medicinehawk01 (**) Date 01-03-2009 01:33
Try up grading to a laser plumb bob. About 100 bucks, but not affected by wind and never needs rewinding. The real drawback is it doesn't work well outside on sunny days, but inside it is awesome. Wish I had one 20 years ago.....jeez.
