Up Topic American Welding Society Services / Technical Standards & Publications / D1.1 (08) stud material
- - By hogan (****) Date 01-07-2009 22:37
Anyone know why the stud material has changed from ASTM A 108 in 06 and ASTM A 29 in 08?
Parent - By ctacker (****) Date 01-07-2009 23:13
correction made to ASTM Specification reference(stated in the foreward)
Parent - - By HgTX (***) Date 01-08-2009 17:30
In 2003 the material information shifted between A 108 and A 29.  A 108-99 has those GXXXX designations.  In A 108-03 all those are gone.  Maybe ASTM decided having the grade designations in both standards was redundant.
Actually, the way the example ordering information reads in A 108, they encourage you to use SAE numbers rather than grades of A 29 (even those are SAE numbers), but yet the text of A 108 says you want to refer back to A 29 for your composition.  But I digress.
Hg
Parent - - By hogan (****) Date 01-08-2009 19:14
I went back to my oldest D1.1 (96) and it references A 108. As stated by ctacker, the forward states it was a correction made to ASTM reference. Was the correction due to the changes you reference? Was there another reason?
Parent - By HgTX (***) Date 01-08-2009 20:17
I assume it was.  We had to make a similar change in our state specs.  You can't refer to "ASTM A 108 Grade G10100" when no such thing exists any more.  They haven't made this change in D1.5 yet but it's probably coming.
Hg
