Up Topic Welding Industry / General Welding Discussion / Please suggest wire for A-106b
- - By sparkycanuck (*) Date 12-07-2001 20:19
Can anyone recommend a good self-shielded (or possibly a gas shielded ) wire. We are doing butt welds on piping. Material grade is A-106b.We would like to speed things up a little by using wire instead of S.M.AW.
Parent - By RonG (****) Date 12-07-2001 20:43
A-106 B = P-1 Gr. 1
Assuming you are using Carbon steel filler. Don't know your requirments but
Dual shield E71T-1 (flux cored useing straight CO2 or 75%/25%)
E70T-7 needs no gas shield and has a high deposit rate.
But Changing processes requires requalifying the procedure, you might want to make more inquiring befor you switch.
