I am not familliar with that machine, but an old Hobart I have runs at different speeds for welding and Aux power. Weld speed is 2200 RPM, and for 60Hz aux. power it has to run 1800 RPM.
My suggestion is to get a volt meeter and measure the frequency, with a meeter or by running an old fashoned clock from the aux. power and compairing to a watch. Get Your best compromise between frequency and voltage under load.
With the machine I mentioned I have to run more RPMs than I should to get enough voltage under load, and the frequency ends up being 70 HZ. Time flies... :-)
