Hi guys,
I will make a fillet weld between plate A36 (35mm thk) and pipe A333 Gr 6 (Ø18", WT 14.27mm), the pipe supplied has Ni (0.1%) and Cr (0.16%), with these values the Ce is 33, I have not experience with that material, Any suggestion? Is necessary any action to prevent problems?
Thanks for your comments,
JUAN
