Up Topic Welders and Inspectors / Welding Equipment Classifieds / 350 Short Block for sale
- - By Jriley1972 (*) Date 01-11-2009 17:27
I have a complete Chevy 350 Short block.  Two piece rear main seal.  This is more or less a stock rebuilt motor.  It has flat top .030 silverlight pistons, clevitte bearings, milling double roller timong chain and milling H.V. pump w/ all steel pumpdrive.  The cam is a tork cam but I will replace with stock type if someone request.  The rods were resized and new rod bolts installed. The engine is currently ready for any color paint someone may request.  I can easily add stock/aftermaket heads, cast/aluminium intake and tins to this engine for additional cost.  I'm located in Conroe, Tx. You can give me a call at 936-444-7392. If you have any questions.  I also have other engines available and many parts if insterested.
Parent - - By Neoslim222 (*) Date 01-13-2009 14:12
2 or 4 bolt main?
Parent - - By Jriley1972 (*) Date 01-13-2009 15:33
This particular one is 2 bolt
Parent - By Jriley1972 (*) Date 01-13-2009 15:37
I may be building a couple of more or could build to a specific reqest.  Im tring to clean out my shop of all the speed and engine parts currently right now. So if you guys have any request or need anything just holler and Ill look through everything I got and see.
