Up Topic Welding Industry / General Welding Discussion / local 798
- - By james webb Date 01-12-2009 05:51
I know om new and asking alot. but i put in my ap to 798 and they approved it. now i have to go and take a 24" bell hole test. is anyone here a member? or does anyone know how strict they are on weld appearance. im not the best @ downhill but it looks pretty good and i try like hell.
Parent - - By gotpipe597 (**) Date 01-12-2009 21:55
They time you on the root. from what i hear it is a tough test
Parent - - By pypLynr (***) Date 01-13-2009 02:52
My buddy is a member and he told me that you have like three hours ,I think ,for the whole test . Thats from coupon cut  to  finish cap . That don't leave much time for error or smoke breaks .  If I were you , I would practice with some 3/16"  and get comfortable with them .
Parent - - By texasrigwelder (**) Date 01-13-2009 03:27
24 inch 500 wall 18 straps is what i had cut i think maybe 12 cant remember, a lot of niks is all i remember they checking to make sure you aint dirty thats for sure, youll tack it up in air clamps then put bead hot pass theyll look at er then so on its just another test there good ole boys your nipples will be cut it aint bad good luck maybe see ya around
Parent - - By cdd (**) Date 01-13-2009 03:47
24 inch 500 wall, 12 straps(4 bends 8 breaks), the test is not timed, they have someone run your heat on your bead and then you are on your own. You fill and cap with 3/16 70+, They look at the bead and then they leave you to it. Not bad. Great guys to work with, if you have any questions dont be afraid to ask them. Good luck.
Parent - - By fordsux8269 (**) Date 01-13-2009 03:54
Its a puddle cap right?
Parent - - By texasrigwelder (**) Date 01-13-2009 03:57
ya puddle cap, and thats right 12 straps
Parent - - By texasrigwelder (**) Date 01-13-2009 03:58
oh and they had me run my bead with 6p+
Parent - By fordsux8269 (**) Date 01-13-2009 12:52
I ran that in Wyoming it doesnt wanna blow threw like 5p+ does. I didnt care for it much. But I was also just breaking out back then
Parent - - By 52lincoln (***) Date 01-14-2009 01:14
what do you mean bye run your heat for you?
Parent - - By hotrodtodd (**) Date 01-14-2009 01:57
it means adjusting your fine tune amperage knob either on the machine or a remote but majority of pipeliners will have a remote and their helper will "run their heat" up and down while he is actually welding you may have heard or read about up 5 down 5 etc
Parent - By cdd (**) Date 01-15-2009 03:43
If they will let you use 5p+ do. they run better
