Generally speaking but, if I remember right; When the welder changes process it is considered an essential variable change. So if the welder did the test and is certified for GTAW, then the welder is not certified for GMAW.
By Lawrence
Date 01-17-2009 18:58
Edited 01-17-2009 19:02
Fast guy
Welder performance quals for D17 are based on process and material.
if the process changes....... requal
if the material changes (from one of the numbered catagories to another)... requal
So to answer your question... Yes a qualified GTAW welder must seperatly be qualified by testing before he/she may do GMAW on the same material.
Furthermore, Under D17 the procedures must also be requalified if a change in process occurs. to truly comply with the code... If a process change is directed for any reason (good or bad) it means the WPS must be rewritten and qualified by testing... There are no pre-qualified procedures ... so just changing the wording in a WPS is insufficient.
