Hello Pat, there are a number of different types of "hangers" that are used by electricians, plumbers and pipefitters, HVAC, and likely many other of the other crafts. As you mentioned though, the ones that you saw could have been fabricated on site to serve a particular purpose. There are a lot of simple hangers that are designed to use all-thread so that there is a lot of adjustability. Others use straps, flats, or angles, that have sequentially punched holes to allow for multiple uses and adjustability. You might check with "Ferguson", "McMaster Carr", "Grainger", or some of the other industrial suppliers for additional choices. I know of the sorts of things that you have described in your post, takes a bit of hunting though to find a specific item. Best of luck and regards, Allan
