I also have no idea of what kind of steel is that, and this is the first thing you should care about.
You say that " ... they are using a 7018 SMAW rod ..", which means that they're presently welding the straps. Didn't they prepare a WPS before starting welding? The WPS should clear up what kind of steel it was intended for.
W59-03 has a lot of search references to G40.21
"3.2.1 CSA Standard G40.21, Structural Quality Steels
Steel base metal to be welded under this standard shall conform to the requirements of CSA Standard G40.21 in the following grades:
260W (33W) and 260WT (33WT)
300W (W44) and 300WT (44WT)
350W (50W), 350WT (50WT), 350R, (50R), 350A (50A) and 350AT (50AT)
380W (55W) and 380WT (55WT)"
and so on
See also "Table 5.1 Filler-Metal Requirements for Exposed Bare Applications of CSA Standard G40.21"
It lists the SMAW Electrodes as "E5516 or 18-C3, E4916 or 18-C1L, E5516 or 18-C1" and so on.
As you can see you still don't know what the embed or strap material is.
As for the electroplate I can only assume it's for in service corrosion problems.
Does you contract docs tell you anything about the connection or material?
