Zeek,
if your great concern is distortion, then a double V joint is the best one, rather than a J or K, as I suggested on the other section of the forum.
I've got with me a booklet published by Lincoln and titled (in English) "The welding shop foreman's handbook", where a chapter is dedicated to how to prevent distortion. The book is printed, not in electronic format, but I can fax you the interesting pages if you let me know your fax number, including area code. The book is written in Spanish, but this shouldn't be any problem, because I've heard that a good part of welders in the US are hispanic.
Another place you can draw information from is the TWI's site (www.twi.co.uk). TWI is The Welding Institution of the United Kingdom.
A word of advice: it's been awful expensive to cold roll two pieces of steel 33 inches long and 2.25 inches thick, so, don't start welding until you've planned a good welding sequence so as to minimize distortion, and I stress the word "sequence", rather than "procedure", because procedure will guarantee the weld quality, regardless of warpage, and sequence will guarantee the weld straightness.
One thing we do to minimize distortion is to use a 2/3 - 1/3 depth bevel and weld the 2/3 side first. (For 2.25 inch thick you probably want 1.5 and .75 depths)
This places the root and next 1 or 2 passes near the centerline of the plate so that weld shrinkage does not tend to cause bending - which causes most of the visible distortion in welding.
Maintain your preheat, weld out the root and if you can, halfway out the large groove side. Then backgouge the shallow side to sound metal and put a few passes in there. As you build thickness, you gain more resistance to bending.
It is important to maintain your preheat through the thickness and avoid having one side hotter than the other.
To figure shrinkage I use Lincoln Electric's formulas:
Transverse shrinkage = 0.10 (weld cross sectional area divided by weld thickness)
I don't know the formula for axial shrinkage but I don't think that shrinkage will cause you much of a problem, 2.25 is pretty stiff.
