Sorry to bring up the old thread - but this question has been brought up recently.
Let me see if I understand this....
You can use the 70S-6 if the C of C shows Mn and Si content below or meeting the 1.6 Mn or the 1.0 Si requirement?
If the Mn or Si content is above, then it does not conform to the A# of 70S-2. In fact, it does not conform to ANY A#....what then?
QW404.5(c) states that the chemical analysis from the weld deposit or from the Mfg's or suppliers C of C can be used (paraphrased). So let's say you actualy do another PQR and the 70S-6 has a Mn of 1.7 and a Si of 1.2, then you're qualified to use the 70S-6 only up to those levels?? What if you get the next batch of wire with a Mn of 1.8?
If I'm seeing this correctly, no matter what, you have to have a serious control over the 70S-6 wire, whether you use it under the 70S-2 PQR or create a new one for the higher levels??
Thsi A# thing is throwing me off too. If it doesn't fit into any particular A#, what do you do then?
